I’ve got a Reloop Mixtour which has no jogs or pitch bend buttons, and I would like to see pitch bend buttons in the hardware view. I think it can be very useful for the controllers which has no jogs. I don’t know why the got rid of this buttons in this view!
Hi @Josemg, thanks for sharing your feedback. The idea behind the Hardware View Mode is to remove the common onscreen controls that are found on most hardware to make more space for other things. You could switch to Pro View Mode or you could MIDI map a Shift layer for two buttons on you Mixtour to pitch bend.
I have also forwarded this suggestion to the dev team for consideration. In the meantime, please use the blue Vote button at the top left of this page so we can gauge user demand for this feature. Thanks!
