Hello,
Unsure why but I’ve started to use Djay Pro 2 with my Denon MC2000 mixer and neither pitch control is working. It is set up using the standard configuration settings.
Sometimes it works, but not properly, for example: If I press the sync option on the left deck, I can slow down the right deck using the pitch control (and only slow down). This is the only case in which it works.
Has anyone seen this before/have any idea how to fix it?
The MC2000 was tested and works fine with Serato.
