I’m using a MacBook Pro M3 and facing a strange issue with Djay Pro. When I move the pitch control towards + on my controllers (S-9, Rane 12, and Rane 5), it moves the pitch in the opposite direction (towards -) in the software. Sync is off, and I’ve tried adjusting all the settings, but the problem persists across all devices. Any solutions?
Hi @SimpleSimon, please navigate to the djay Settings>General>TEMPO> and adjust the Invert Slider as desired.
Go to MIDI , move the pitch, below there is a tab that opens where you can change that by pressing invert
It worked! Thanks for the help. Adjusting the Invert Slider in the Tempo settings solved the issue.
You’re welcome @SimpleSimon. Happy to help!
