Pitch suddenly changes, & pitch slider cannot be used to desync
After updating to version 5.3.2, the following problems have occurred frequently, making it unusable in the field.
  1. The pitch (key) of the music being played suddenly goes up and cannot be restored without rebooting the device
  2. While syncing, if you change the tempo of the next song with the tempo slider, the sync is canceled and only the tempo of the next song is changed. However, from the latest version, the sync is not canceled and the tempo of the currently playing song is also changed.
The same problem occurs when I connect a controller and when I use the iPad alone.
I’m in a hurry because I’ll be using it at a big site next week.
For now, can you please tell me how to quickly revert to the previous version?
iPad Air 3th gen
iPad OS 18.5
djay 5.3.2
Reloop Buddy
Not sure about 1st one but 2nd point you make sure your settings are correct.
The latter issue has similar symptoms to this topic.
Is there any way I can get version 5.2.10 right away?
Hi @magokorokun, there is no way to revert to a previous version of djay unless you’ve made a full system iOS backup to your laptop via the iTunes/Music App.
  1. It sounds like you’ve turned Key Lock off. Can you please capture and share a short video to explain this issue in more detail.
  2. This functionality was changed in the latest djay version. This is now expected behaviour.
From the 5.3.2 Release Notes:
• Improved tempo change during sync behavior: if sync is active, tempo changes on any deck will now synchronize with other decks, regardless of whether the deck itself is currently audible
Thank you as always, Slak_Jaw.
  1. The keylock function is ON, but suddenly the key and tempo increase.
After that, I can’t turn the keylock function off, and the tempo doesn’t change even when I move the tempo slider.
This phenomenon occurs randomly, so if I’m lucky enough to see it while shooting a video, I’ll send it to you.
You’re welcome @magokorokun. This sounds very unusual. Please try to capture a video if possible so myself and the engineering team have a clearer understanding of what’s going on. Did this only start occurring with the latest 5.3.2 update? Does this only happen when the Reloop Buddy is connected? Thanks!
This is the first time I’ve encountered this issue with version 5.3.2.
It occurred both when connected to Buddy and when using the iPad alone.
Thanks for the additional info @magokorokun. This is very helpful.
