Place to share all Hardware Mappings
Thank you very much, @Slak_Jaw . I can see in this file that, for every pad mode button you press on the equipment, Djay Pro sets a specific pad mode too in the file. Example: turntable1.padModeInstantFX ; turntable2.padModeHotCue , etc.
So I guess it’s possible to make a 4 deck mapping similar to the one I did in Reloop Ready… Now I “only” have to buy a T7 to try it! :smile: Maybe when my budget is a but higher…
But thanks again!
You’re welcome @Carlos_Alexandre_Cam. Happy to help!
Teenage Engineering EP-136 K.O. Sidekick MIDI Map for Djay Pro
After initially using the Sidekick as just an audio mixer, I wanted to see if I could use it as an all in one “Minimum Viable” DJ controller. Turns out, with a bit of creativity, it makes a great little portable unit with basic transport controls, USB audio and pre-cueing.
Here’s a link to my mapping on DJTechTools - Let me know if you get some joy from using it :grinning_face_with_smiling_eyes:
https://maps.djtechtools.com/mappings/22527
To get it all working, first, configure the Sidekick for MIDI and USB Audio:
1. Go into the settings menu on the Sidekick by pressing the hidden button under the battery cover.
2. Use the orange pitch knob thing to move through the menu until you hit “MIDI”, then hit the Select button.
3. Use the pitch knob to move through the options until it says mode “Control” and hit Select.
4. Go up to USB and make sure the input is set to “Multi”. I also have Out turned on. Select to confirm.
5. Press the hidden button again to exit out of the settings menu. The screen should now say “Control” at the top.
On MacOS, copy the unzipped mapping file to: HDD>Users>Name>Music>djay>MIDI Mappings
On iPhoneOS/iPadOS, copy the unzipped mapping file to: On My iPhone/On My iPad>djay
In DJay Pro, go into Settings>Devices, and choose Mixer Mode: Internal.
Main Output: EP-136 - ch 1-2
Pre Cueing: EP-136 - ch 3-4
Alright, now to what it does…
It’s a two channel mixer with sound card, headphone cueing and basic transport controls.
The buttons, knobs and faders do the following:
GAIN: Moves through library.
GAIN PRESS: Load track to deck. Left is Deck 1, right is Deck 2.
SELECT + GAIN: Scrubs through track.
SELECT + GAIN PRESS: Jump to 2nd Hot Cue Position.
TREBLE, MID, BASS: Does what it says on the tin.
CUE: Turn headphone cue on and off for that deck.
SELECT + CUE: Pitch Bend. Left is -, right is +.
FADERS: Deck 1 and 2 Levels.
FX: Play/Pause Deck 1 and 2.
SELECT + FX: Select which Deck has focus for Pitch Bend and Loops.
BUTTON (Below Screen): Loop 16 Beats On/Off.
SELECT + BUTTON: Loop 32 Beats On/Off.
VOLUME: Master Volume Output.
ORANGE KNOB THING: Crossfader. Defaults to centre.
PHONES: Headphone Volume.
SELECT: Acts like Shift.
Nice! Thanks for sharing @Joshua_Murray
Small Re-Mapping for Hercules Inpulse 500.
FX1, FX3 - Acapella and Instrumental NeuralMix switches Deck 1
FX2, FX4 - Acapella and Instrumental NeuralMix switches Deck 2
Sampler Pads: Beat Jumps 4 - 8 - 16 - 32
Mode 5 top row pads - NeuralMix 4ch On/Off switches (Drums, Bass, Harmonic, Vocals)
Out-Loop button - Double (while in loop; both In and Out buttons were mapped to “Half” by default)
Welcome to the Community @demiz. Thanks for sharing your mapping.
Hi, guys! I finally got my hands on an used Hercules T7. I tried to create a 4 deck mapping it, but It all went downhill :frowning: . The problem is that no midi signals are sent when you touch the platters for scratching. Even de Play/pause button doesn’t send a midi command.
So it’s impossible to midi map scratches for decks 3 or 4. You simply can’t control them from the platters. The other buttons and knobs are mappable, but the ones in the FX area are a bit tricky too.
I believe this propably applies to other controllers like the Rane One, too…
That’s too bad! Thanks for sharing @Carlos_Alexandre_Cam.
Hi @Slak_Jaw . Do you know if anyone has a DDJ RR mapping ? I know it’s not supported on IOS, but only the sound card doesn’t work, the rest works (I’ve seen it working…).
I don’t know if anyone has mapped this for djay on iOS. Have you checked here?
@Carlos_Alexandre_Cam, here’s the (built-in) mapping for desktop. You could try using it on iOS and see what happens:
Pioneer DDJ-RR.djayMidiMapping (282.8 KB)
This is just what I needed. Thank you very much!
Even easier, the iOS app has the same built-in DDJ-RR mapping as the desktop version. Simply connect the RR to the iOS device and the midi will work. The audio output from the RR does not work because the controller is not class compliant, but you can solve it with an external sound card
Thanks for confirming @Pg_Gee
Thank you, @Pg_Gee ! I’ve already seen it happening exactly like you’ve described. If I put my hands on a RR again, I’ll use the external card!
I was looking for the mapping to see how it is in more detail…
Thanks for the follow up @Carlos_Alexandre_Cam. That makes more sense now.
