Please add an option / switch in the settings where you can set that the play count comes from the ID tag and is written.
Maybe you can implement this so that there are 3 choices.
- is stored in the Djay library (database).
- is saved in the ID tag of the music file.
- is saved in both.
When activating the first time, you could offer the option to synchronise the count from one to the other.
So following selection possibilities.
- From Djay to ID Tag
- From ID Tag to Djay
- None of both
Thank you very much
With kind regards
