Play Podcast on Djay 2
I have found some podcast on iTunes that I wish to play on my WEGO through Djay 2. Is that possible?
Hey N. Siotto,
the usage of iTunes podcasts is not supported.
Are you downloading the podcasts via the iTunes App Store?
Cheers,Lukas E.
Don’t know why but I wasn’t notified of your reply. Thanks a lot for the info. Yes I am downloading from iTunes.
