I can see a few songs that I purchased using iTunes, but if I click the icon for Apple Music the only option is for me to sign up and stream their music, which I do not want to do. If I click the blue music note, about 19 of over 500 songs appear. Below that, there is a red music note inside a white circle. When I click that it says “iTunes library not found”. What am I doing wrong here?
Hi @NewandConfused,
- First, please make sure Local Music is enabled in the library view.
- Then navigate to the Local Music icon instead of the Apple Music icon to access the music you purchased from iTunes.
- Please note that this music must be downloaded onto your device to be playable.
