playlist djay 2 android
Can I change the order of the songs in the playlist? thank you
sorry for my english i am italian
djay 2 for Android is getting the playlists from the Google Play Music app, if you change the order of the songs in the Play Music app, djay 2 will get synchronised.
Hi Paul,
which Android device are you using?
Cheers,Lukas E.
ok…
I can’t use Play Music tracks. Have had to download the same ones by android file transfer - but wish I could access the music under the playlists tab in google music.
Am I missing something?
Paul
Nexus 7
