Your question:
With both Tidal and (latterly) Spotify, I was able to export a DJ set playlist from the history tab. With Apple Music (which otherwise I love) this option seems to have disappeared.
Hi @DjXlibris, it shouldn’t matter what your music source is (Tidal, Beatport, Apple Music, etc.), djay automatically saves the history of every DJ Set.
Simply open the My Collection Source in the left pane,
Select the History tab at the bottom of the Playlist pane,
Select the the history playlist you want to export,
At the top of the playlist select the dropdown menu by the number of songs in the playlist,
Finally select Add All to Playlist…
Please note that this playlist will need to be added to the My Collection source, not to the Apple Music source.
