Playlist filters applied to whole library not just individual Playlist
It would be great if we could set filters and they apply to all playlist so we could jump around quicker and find songs based on what parameters we have set. This feature was just added in Virtual Dj (quick filters) and it makes finding stuff soooo much quicker and easier. This should be easy to implement since Djay already has filters.
Hi @Blend30,
Thanks for posting this question in our Community. I’d like to point out that we’re currently improving the filtering system on the djay library. In order to better assist you, we’d need to know the following information:
  • what device are you using?
  • what iOS/macOS/AndroidOS/Windows version are you currently running on that device?
  • what djay version are you using?
Hope to hear from you again.
Cheers, G
