Playlist for both itunes and spotify
How do i create a playlist that contains both spotify and itunes songs?
(Djay pro for mac)
Please note the only way of creating playlists within djay Pro is by exporting your history. You can create either an iTunes playlists, or a Spotify playlists. It is not possible to create any mixed playlists.
Nevertheless, you can use the Queue to get songs from both libraries together.
They will automatically be exported to your Spotify / iTunes library. After refreshing your library, they will be available within djay Pro, as well.
Is there any way to import those exported history playlists?
But that still does not allow me to create a playlist for both iTunes AND spotify tunes?
