I have a playlist for a party and I want to leave it alone and not actually manually mix the songs. But I would like the songs to mix from one to the next would that be possible?
Hi @Vicster933, you can definitely do this with djay Automix. You can read more about Automix in the macOS djay User Manual in section 4.6.
To start using Automix:
- Switch to Automix view via the layout dashboard.
- The Automix side panel will display the currently selected playlist as your play queue.
- Hit the Automix button to start Automix.
- Tweak your Automix settings in the preferences.
- Repeat or shuffle your queue.
- Edit your start/end points to choose where the transitions happen.
- Quickly access your Automix transitions.
NOTE: The quantization of start/end points can be set via the Q menu in the cue point
panel/toolbar.
