It would be really great if a playlist was created of songs that have been played in a mix and then when finished you were asked if you want to save those songs in an iTunes playlist.
We’re proud to present djay 2. This feature is now implemented in this new version. The History feature saves played songs for a session. Check it out!
The history playlist cannot be exported on djay for iOS.
Where is this implementation? Thanks
How can i export the file of tracklist? Thanks
good idea!
