Playlist organization on Djay iPad
hello
about djay playlists, i like the feature to sort by key. but then i’d like to be able to re-organize (move) some tracks before or after another one (after the sort). unfortunately you cannot move tracks if there is any kind of sort active.
so could you add a way for us to move tracks within playlist even if they are sorted ? (i understand that sometimes they won’t be “sorted” :slight_smile:
perhaps you could add a button to define the sorted playlist as the new default order ?
or when you create a new playlist from the sorted tracks it becomes the default one?
i hope you understand what i mean
we definitely need to be able to manage djay playlist the way we want (like all other software do)
Regards
Using djay playlists with my mp3 bought and stored directly on my ipad
by the way, we should be able to (re)organize any playlist as soon as it has been transfered into a djay internal playlist, and that’s already working. my only problem is that when a playlist has been sorted you cannot adjust it and make some minor moves into it.
regards
No. You’re using Spotify, which has a different format.
Please, please, buy a real controller and legal music. One internet glitch and and you’re stuck, which makes is all look bad.
Plus, if you’re charging, Spotify is not technically legal, although it’s unlikely you’ll ever get busted.
And even though I hate the RIAA as much as anyone, DJs need to support the music industry.
[Speed Test Scrabble Word Finder Solitaire](https://testmyspeed.onl/ https://scrabblewordfinder.vip/ https://solitaire.onl/)
