Hi all,
I did upgrade from DJay to DJay Pro a while ago.
I am looking for the option to save the songs played.
In the past I was able to save the playing order and import the playlist directly to Itunes.
Since I upgrade I did not found the option.
Where can I find it???
Any help is welcome.
Holger
And why can’t I directly export playlists? Or can I? (Now I play a part of all the songs to put them in the history and then I export them.)
In order to export one of your mixing sessions to an iTunes playlist, simply click “Export” here:
You absolute legend! Found mine from last night, so helpful!!
Where is this feature in DJAY PRO 2 ???
please help
