Playlists are automatically reorganized with Tidal after I put them in the order I want
I’ve not had the playlist order changing all by itself before. It’s only happening when adding/reordering/removing tracks from inside of DJPro.
And this is a problem that only started in the last 6 weeks. Been using
DJPro for 2 years arranging playlists within DJPro and never had this
happen before.
Yes, same here. Recent phenomenon.
happen before.
So… as djpro haven’t had a new release since several weeks, the change has been done on Tidal side.
What I see is that Tidal is open up their API.
https://developer.tidal.com/
Will the music in your local files change order as well? If not, you can try to download the Tidal music and import it as a local music file to your device. Many third-party tools can help you achieve that, like the AudBite Tidal Music Converter.
