Hi everybody at algorithm,
I am a Dj for Rock music, and I have at least two things that would be awesome to be changed with a future update of Dj Pro…
First, why am I not able to sort my playlist in Tidal individually?
Or even better: why can I not select some relevant playlists i do extra put together for an event.
The actual version always shows me all the playlist i ever made on tidal. (Including privat stuff like playlists of my kids or my favorits that dont really match with te stuff i dj with)
The secound wish is even deeper:
It would be great if I would be able to hide the songs of a playlist that were already played. So the playlist would become smaller the longer the event lasts, and the chance of forgetting songs would be minimized…
Please think about it!!
I believe these suggestions ate not really difficult to add…
Would be great though
Thank you so much
Greetz Dj Maihou
(from Murnau/Garmisch, so you guys ay algorithm are invited to come to my parties :-))
Hi @DjMaihou, thanks for the suggestion. Regarding number:
- I recommend that you create your playlists within the My Collection source if djay rather than within Tidal. You have a lot more sorting and organizing options here. Plus My Collection playlists can contain songs from multiple music sources like Tidal, Apple Music, Beatport and Local Music.
- You can use the Queue to achieve something like this. Then in the djay Settings>Library you can select Remove Songs from Queue when Played. You can select an entire playlist and add it to the Queue as well.
Sorry, didnt find your answer before today…
your answer doesnt really help.
of course i have the songs removed from the Queue when played.
I do always add songs from different playlists into the Queue…
The thing is that my playlist for the set are pretty long.
I would like to have them melt during the set, so it is easier not to forget anything in the end…
The more important thing would be to just tell dj pro which playlist i need for the set.
Or better, tell djpro which ones i DONT want to be shown. or at least have the be shown in alphabetical order…
I have two kids using my tidal. its really unnecessary to have those list to be shown during a dj set…
You should learn to use the “my collection”.
If you want to see only 1 playlist from tidal, that might require a setting on Tidal side that “this playlist is visible to dj tools”.
So that djpro could sends a request to tidal “get all playlists from user X which are visible to dj tools” .
Now djpro can only send a a request “get all playlists from user X” .
