Would be nice to be able to select a playlist for Automix as per Automix playlist not showing playlists
–The only way to get it to change to another playlist is stop + start or play a track from the new playlist which isn’t ideal if you want to just change it on the fly. -
When you right-click a playlist, I was suprised to see the only option is ‘Delete’ - there’s many features which could be added here such as:
– ‘Automix’ (Changes the automix playlist to this playlist),
– ‘Shuffle’ - Could shuffle the order of the playlist’
– ‘Export’ - Export the playlist to CSV or text file etc. -
Double-clicking a playlist should be a configurable option - options could be:
– Make the playlist active + play or shuffle play
– Start automix of playlist
– Edit playlist -
Automix transition option is either ‘Automatic’ or selecting only ONE of the transitions - it would be great to be able to toggle each one on/off. I did raise support case #157110 but have not heard anything back!
Option to randomize playlist order (Like a shuffle button).
– A playlist can be ‘ordered’ but there’s no column for the order
