Please add ios support/compatibility to standard club mixers such as Pioneer Djm 900nxs2 and Pioneer Djm-750mk2.
I cant wait to get to my recindential clubs with my Ipad.
You are barking up the wrong tree. Try the Pioneer forums.
To give you some ideas…
@DJay_Dizzle As already mentioned in your other thread on the same subject, it’s not possible.
If the manufacturer doesn’t design the product to work with iOS, then there’s nothing a software company can do to “add support”.
Fun fact. The XDJ-AZ works with iOS
theres just no official midi mapping for it. So one has to map it. But i believe most if not all gear comming out now will be class compliant with iOS.
