Please change the 3 bottons play, set and return by the play/pause and cue bottons. Is more easy.
100% yes!
… Or make it an option in settings.
That’s standard amongst most software, and hardware. It’s very difficult to learn the “Djay Pro” work flow when you are used to the industry standard, especially if you continue working with more than one software solution.
