Djay’s Fluid beatgrid is fantastic 99% of the time, but for the 1% of the time it does not get it right, it is pretty frustrating to edit the beatgrid and get it corrected manually.
There is a real issue when it comes to editing beatgrids.
TLDR - Please try mapping Go Back by John Summit and Sub Focus, and you will understand my pain points.
There is a part in the middle of the song where the song jumps from House around 136 bpm to Drum and Bass at 174 bpm. The tempo shift is gradual but also very fast in the sense that it happens in just a few bars. Djay does not keep up with this all the way.
Now that would be normally not much of an issue as you could just go and edit it to get it right, but grid editing is not functional at all.
Firstly, the metronome is not accessible within the grid mapping menu. The sampler has to be open, and it turns off upon pausing the track, which you would want to do multiple times when you are tempo mapping. You have to turn it on each time you hit pause.
There is no easy way to tell djay what the tempo is after a certain point. There are anchors but they do not do anything other than get djay to adjust the AI.
I get that ideally the AI should handle all cases, but fundamentally it is pretty important to have a good grid editor as well, as there will always be some cases where the AI does not behave as expected.
