Hi, I use DJay Pro 2 specifically to stream into virtual worlds (specifically SecondLife) Up to now I have captured the audio and sent it out to the icecast servers using Nicecast from Rouge Amoeba, however, as you may know, Nicecast has been dropped. Whilst there are other alternatives such as Ladiocast which streams nicley, there appears to be no way to extract the nowplaying.txt info from inside the DJay Pro 2 package and send it as metadata to an external streamer.
It would be great to have this functionality direct in DJay Pro 2 so with a touch of a button your broadcasting.
