Possible to have Drum - Bass - Harmonic
Hi
I’m wondering in the Settings > Sound > Neural Mix EQ
Is it possible to have “Drum - Bass - Harmonic” leave Voice as it is..?
I understand that it is super similar to these two posts:
i’m not sure which one to post the question/request?
Hi @PoyTB, can you please clarify your question with more details?
You can already choose Drum-Bass-Melodics in the Settings:
DRUM-BASS-MELODICS NM VOLUMES:
DRUM-BASS-HARMONICS-VOCALS NM VOLUMES:
Sorry mate, late to reply!
As per your screenshot “Melodics” contains both the harmony and voice together.
I want to be able to control just the harmony without affecting the bass or voice.
Hi @PoyTB, per the third screenshot above, if you switch to 4 STEMs instead of 3 STEMs, you can control the Harmonics without affecting the Vocals or Bass.
I’m hoping that if you create Say “bass - harmony - vocal” under that setting.
i might be able to map out the knobs to the above, rather using the ipad control (which i am currently doing)
Hi @PoyTB, it’s unlikely the dev team would add a third 3 STEMS option for Bass Harmonic Vocals as this would result in the Drums STEM not being controlled. I recommend that you use the Drums Bass Harmonic Vocals option and customize your MIDI mapping accordingly.
Please note the with the existing Drums Harmonic Vocals option that the Drums includes the Bass frequencies as well.
