My FX routing is set to Post-Fader in the mixer options.
When for example I want to enable an Echo on just the vocals (see screenshot), the post-fader fx seems to change to pre-fader. I hear the effect but it gets cut as I pull the fader down.
If I use the same Echo on the full deck, it works fine post-fader.
Would love to see these NeuralMix effects enabled post-fader
Hi @bootlegger, this is a known performance limitation of Neural Mix. The dev team is investigating options, but this is a complex issue. See the linked topic below for more details. Thanks.
While looking for a fix for this, I found this thread. I used to use it like this in Rekordbox, but when I try to use it as a post-fader in djay Pro, I end up with a very harsh cut in the volume. I hope they fix it.
