Hi guys,
perhaps someone else has noticed, but the characteristics of the pots are not necessarily the most appropriate.
The volume in the top 10% controls 50% of the total volume. And in the lower third (or half), you essentially barely hear a difference.
This is a problem because it makes 30% of the pot redundant and makes it harder to mix. Thus, every small movement has a BIG effect on the output signal in the upper third, which is understandable with a violin, but not necessarily with a dj controller.
And the EQ pots cut very quickly and a lot out of the tone, maybe it might be worth a look. For example, -33% is already plentiful and very-very audible, yet it’s a very small part of the whole pot’s journey - it also makes mixing difficult.
I hope these things are manageable.
Imi
