Power supply USB-C with integrated hub
I want to connect the iPad A16 to the Mixon4 with as few cables as possible, I was thinking of a USB-C power supply with an integrated hub, does it exist?
Reloop Stand Hub…or
Any hub with a power supply that’s compatible with iOS. Tons on Amazon. just be certain it has charging capabilities.
you didn’t understand the request or maybe I wrote it wrong, I’m looking for a power supply with an integrated hub, from which two cables come out, one goes to the iPad and one to the mixon4
Oh well I can’t think of anything like that to reduce the amount of wires you’re using.
You will always need the power/usb connection for the iPad. The usb cable for the Mixon, the Mixon power cord and the power cord for the power supply.
UNLESS you used something like a Jackery battery with USB. OR go with a Bluetooth setup. Or the alpha theta wireless kits and something similar. Hercules has a wireless controller. Hope it helps.
Just buy a docking station - if you don’t want dongle
If it exists, it is extremely rare.
Best bet:
→ USB-C hub or docking station
→ with PD (Power Delivery) support for 60-100 watts of power.
I can’t speak for the mixon 4 but I know that a lot of controllers require earthing via mains power for the jog wheels to function properly. You may want to investigate this before making a large purchase should you find something
Thanks for sharing @Armigo, @Michael_Wisniewski and @daniel_curley
