Is there a proper or improper way to start up the iPad with the Rane One Connected? Should the hardware power up first, then turn on the iPad, or vice versa for the most stable connection? Thanks in advance.
I don’t know if this is the proper way but I always switch the Rane on first then open the App…
Seems to work for me…
Cool, thanks. I’ll try it that way.
Got it. Thanks! Do not turn off the controller and iPad, and don’t touch the source switches.
I can’t speak to the Rane One, but I’ve had issues in the past with djay sometimes not being able to read my controller. This is the connection sequence that I always use now and it seems to do the trick.
