Hi guys there are know longer cue buttons when using 4 deck mode.
Please see bellow
Tap on this button. Then tap n the arrow with the dot.
He’s talking about the headphone cue icons shown in the second photo. It doesn’t exist in horizontal 4 deck mode on the iPhone version
Hi @Djdash,
Thanks for bringing this to our attention. Could you please tell me what model iPhone you’re using? And also what djay version? Thanks in advance!
Hi there. Same here iPhone 13 Pro Max latest version of Djay
Thanks for getting back to me @Djdash and @Myalteredsoul. I’d first like to confirm with both of you if you do find the headphone pre-cue icon in djay on your iPhone in landscape orientation by following these steps:
- Please first make sure that a pre-cueing option is chosen in djay’s Audio Device Setup settings. As shown below, “Split Output” has been chosen here:
- Open 4-deck mode, with your iPhone in portrait orientation, and note the headphone pre-cue icon appears when the EQ panel is selected (the fader/meter icon should be blue), as shown below:
- Turn your iPhone to landscape orientation, and make sure the EQ panel is selected by tapping the fader/meter icon to the right of the djay dashboard button at the top of your screen. Here you should also find the headphone pre-cue icon for all 4 decks, as shown below:
Please let me know if this is not the case for you! Looking forward to your replies.
ope. that was it. thank you
Thanks so much seems to be fixed
Emily to the rescue
