having cackle noise in pre-cue on headphones after approx 80mins,its happening with two separate controllers.so must b software issue
thank you for your post.
We are sorry to hear that you are facing these issues.
It would be very helpful if you tell us which controllers, software, device (mac/iPad…), and operating system you are using.
Thank you for the follow up.
Could you explain the sound issues in more detail, or even send us a exemplary video to support@algoriddim.com?
That would help us tons.
vestal spin 2,pioneer DDJ-SB2, on the latest software update on a new macbook pro
