Pre cue on the new rev 7 midi upgrade
I am having an issue with the the channel selection when trying to here the track prior to mixing. It seems that if the up fader is down I can’t here the track . When I slide it up then I here it. I’m using my iPad in external mode. I did midi map my up faders as line 1 and 2 volume so I can see them on the app along with the knobs and also check box in preference tab for pre cue with rev 7 ch 1/2. Any suggestions
It sounds like you have the Cue/Master Mix dial turned all the way to the Master side. This dial is located to the right of the headphone level dial. Try turning it all the way to the left or Cue side.
