For some reason I can no longer cue in my headphones using my DDJ-SX, I have had no problems in the past, then all of a sudden, no sound in the headphones when cue function activated. Master cue works sweet.
Software is pretty much useless if you can’t pre-cue.
Any help much appreciated.
Hi Si,
please check if the controller is correctly used as an external mixer device.
If that is the case you pre cue solely via the controller.
