Pre-cue split output for MetaQuest3 headphone socket
Hey all.
Given that Algoriddim (seemingly) hasn’t thoroughly checked implementation of midi controller functions for all the supported controllers it lists as compatible —a glaring example being the Numark DJ2Go2 which has no headphone / pre-cue working…
…I’d say it would anyway make sense to implement split pre-cue because the MetaQuest headset has a dedicated 3.5mm stereo headphone :headphone: socket.
Even for those not using hardware controllers it helps make a very portable setup.
Thoughts?
Thanks for the suggestion @dirrogate.Good idea. I have forwarded this to the dev team for consideration. Thanks!
Hi @dirrogate, this has been added in the 1.2.0 update for Quest:
Added option to use split output (left = main output, right = precue output)
