Hi all. I have done this in the past with other apps, but for some reason I can’t seem to get this working with Dj and my iPad Pro with USB-C output. I have select it pre-queuing splitter. I have a splitter cable and it’s not working how it should any ideas.?
Hi @Nubium,
- Please try disconnecting all of the cables and adapters
- Close djay Pro
- Perform a Forced Restart of your iPad Force restart iPad - Apple Support (CA)
- After rebooting, launch djay Pro
- Finally, connect your USB-C headphone adapter, then connect your headphone splitter cable then connect your headphones and speakers to the splitter cable.
- Now go to Settings>Audio Devices>Pre-Cueing and set it to Split Output.
thanks for the input. u da man!!
on further testing the usb c to 3.5 mm female adapter is only mono!!! dohhh…
You’re welcome @Nubium
