Pre Cueing Djay With Android and Reloop Mixtour - Bluetooth
I Have bought the Reloop Mixtour. I want to use with my android phone (Huawei p20pro). I connect my Android Phone with the mixtour using OTG to USB C cable. Can control the Djay very well. The only problem I have is that the Mixtour has a 3.5 Headphones jacks that when I use the Phone does not work.
I connect the Phone to a Bluetooh column by Bluetooth. Everything is ok, except the pre cueing that I really miss in this set up. I believe it has something to do with using the bluetooth as the way out, but really would love to be able to use A phone + the Mixtour Controler + Bluetooh column as this would be very portable. Is there a way other than the split cable? If I use the split cable I loose too much power…
Thank you.
Nuno
Hi Nuno,
I’m afraid there’s no way to have Bluetooth audio and pre-cue at the same time.
