Hello I am not able to use the pre-cueing feature on my Hercules DJcontrol Mix.
Even if my headphones (AirPods ) are connected I can’t see them as an option in the pre-cueing combo menu.
So I am not able to listen the upcoming song. Can you please help me?
Thanks in advance!
Hi @Andrea2013,
You need a wired headphone connection for pre-cueing. This cannot be done with wireless headphones. Please refer to the Hercules DJ Control Mix user manual for more details.
- Connect the speakers/headphones DJ splitter cable (included with DJControl Mix) to the headphones output on your smartphone or tablet.
- In djay Pro AI, tap the Dashboard button, then tap Settings to access the app’s settings.
- Enable Split output – Enable split output for precueing with audio adapter.
- Connect your headphones to the green output on the speakers/headphones DJ splitter cable, and
your speakers to the black output. - When you want to monitor a track, simply push the Monitoring button or on the DJControl Mix
controller corresponding to the track that you want to monitor.
