When trying to listen to a song in head set it’s also heard in the main output/speakers
djay pro 2 v2.0.11 on Mab book air with OS Mojave 10.14.3
Pre-Cueing: “USB sound card” (Plexgear USC-100)
Main output: “Built in output”
Cue/mix is all the way to the left
Split cue: off
Loading a song on deck 1
Fader to the right
pressing play
and finally the headphone symbol under deck 1
Sound is now played in headphones correctly but also in the main output left
Same goes if I play a song in the main output it’s also heard in the headphones without Pre-Cueing it
Same problem when i use a blueooth headset instead of the usb sound card
