Pre-cueing with DDJ-200
Hello, I’m hoping someone can help me with the following issue with split output and pre-cueing. I’ve listed my setup and the result below;
Equipment:
MacBook Air running Big Sur 11.6.8
djay pro AI 4.0.3
Pioneer DDJ-200 controller via USB
Internal mixer selected:
Main output- Built in
Pre-cueing- Split output
Headphone splitter cable:
TRS stereo to dual TS mono
One output to headphones.
Other output to twin active Pioneer DM40 studio monitors via supplied 3.5mm to RCA adapter cable.
MIDI settings for DDJ-200:
Master- Monitor Cue
1- Deck 1 monitor
2- Deck 2 monitor
Result:
All off- Both decks through both speakers.
Master- Both decks through left speaker.
1 + Master- Both speakers deck 1 to right.
2 + Master- Both speakers deck 1 to left.
1- Both speakers.
2- Both speakers.
Nothing through headphones at all. Swapping the outputs gives the same result with everything through headphones and nothing from the speakers.
Hi @RyanLWB2,
Have you tried updating djay Pro AI to the latest version, v4.0.5, in the hopes that - that will solve your issue?
Additionally, could you attach a screenshot of your current audio routing found in djay’s preferences menu? I will attach a screenshot below for reference.
Hi Nathaniel,
All sorted now thanks. For the benefit of anyone else with the same issue, just buy a proper DJ splitter cable and don’t be a donut like me!
Thanks.
