I have a MBP (Mavericks) running Djay 4.2.2 and have a Numark M6 USB mixer. I use the USB connection for main output but need to figure out how to pre-cue upcoming tunes on inactive table.
Is there a easy solution? Other hardware/connection required?
You could use the USB connection for main output and your hp laptop’s built-in audio interface pre-cueing. You can set that up via djay Pro’s preferences on Windows. Hope this helps.
Pre-cueing with DJAY and Numark M6
I have a hp envy laptop running Djay pro and have a Numark M6 USB mixer. I use the USB connection for main output but need to figure out how to pre-cue upcoming tunes on inactive table.
