Decided to give djay pro a shot and bought a mixtrack platinum fx to use with my 4th gen iPad Air. Right out of the gate I am having trouble making precise pitch adjustments when beatmatching. No matter how little I move the pitch fader it almost always jumps .2 bpm. Is there some setting I need to configure to get more precise pitch adjustments? Or is this a mixtrack platinum fx issue? Or is this common behavior across all gear?
Hi there try going to settings then general and changing the value of the tempo slider. Let’s see if this makes a difference.
Forgot to mention that I already tried adjusting the range. It slightly better on the lower settings (that’s where I get .2 increments) and worse on the higher settings. Thanks though.
Hi @Themainman3,
Thanks for sharing!
What is the exact BPM value/increment you would like out of djay?
Additionally, what version of djay are you using?
Also, big thanks @Djdash for the help.
