have problems with precuing on djay pro - when i connect the Griffin Imic and select it for precuing a constant noise gets out of my headphones, precuing impossible! However, in djay 4 precuing with the imic works perfect! How is that possible? What does djay pro different in configuration? Would appreciate any help, djay pro without precuing is worthless…
Since the Griffin imic is an external usb soundcard, your description doesn’t help much… maybe you have another suggest? Obviously Djay pro configures the imic wrong. As described, just constant noise gets out my headphones after i chose the griffin imic for precuing. However, in djay 4 everything works fine…
