There is no option to see the cues and the waveforms together in the same layout. This is something substantial to prepare the songs in iphone version.
Hey Andre,
Do you mean view waveforms and Cue points
With BOTH decks visible?
Hey Andre,
Is this what you’re looking for?
No. I mocked this up with an App on my iPad Pro.
This is the New Djay Pro iPhone. I figured we can inspire The Algoriddim team.
Sorry, yes…the older Djay Pro
There simply is no need for the waveforms to take up so much real estate (on any device). If they use up a lot or RAM, them being High Resolution is not needed.
Right half is actual,
Left side is a wish.
Waveforms could even be thinner.
Hi Andre,
Thank you for your post. Could you please send us an exemplary screenshot? Are you referring to the Hot Cue points on the waveform overview?
Cheers,Lukas E.
Hi guys,
Thank you for your feedback.
I had a talk with our developers, especially about a horizontal waveform view and the fact that you can not have the tools open while seeing a detailed waveform.
I want to say thank you for pointing this out, your feedback is very valuable to us.
We will keep you posted.
Not answering for Andre, but yes, that’s the old Djay version, right?
Thank you so much, Lukas for the feedback. It’s little things like this this kind of reply that go a long way. Appreciated!!
It Would be great to see both decks and the cue points together if that fitted into the new layout (as you did in your mocked). But for prepare cues points of new songs, only one deck and the cue points are enough (exactly like the old version). Anyway thanks to do this.
Hi Lukas. Thanks for reply.
The waveform overview is impossible to make cue points. I assume that when you said “waveform overview” is the waveform located on top of layout). I need to see the detailed waveform and the cue points together (like the old djay version - as I put at the screenshot below). In the new djay you can see just the waveform overview and below this a BIG space with big cue points. You can use this big space to put the detailed waveform and the cue points together.
The waveform overview is impossible to make cue points. I assume that when you said “waveform overview” is the waveform located on top of layout). I need to see the detailed waveform and the cue points together (like the old djay version). In the new djay you can see just the waveform overview and below this a BIG space with big cue points. You can use this big space to put the detailed waveform and the cue points together.
