Pressing BACK on FLX10 does not switch library table
In fact, setting ANY button to switch library table does nothing. The buttons work fine, switching library table does not.
macOS Tahoe 26.1
djay 5.6
MacBook Pro M5
Hi @discoian, since this sounds repeatable, can you please capture and share a short video of the issue to help clarify what’s happening? Thanks!
Hi, sure thing, I’ll do that this week.
It appears that this only happens when the djay window on macOS loses focus, ie if you go to another window, as soon as you click in the djay window again it’s fine. Strange though as other controls such as the rotary for scrolling through tracks still works.
