Preview Songs - iPad
Hi everyone,
I just switched from Mac to iOS and I’m missing the Play button in the playlist area for pre-listening (not pre-cueing).
On macOS I could quickly preview any track directly in the playlist before loading it onto a deck.
On iOS I can only load a track onto Deck 1 or 2 — there seems to be no simple preview option.
Is this feature missing on iOS, or am I overlooking something?
I’m using the Pro version.
Thanks in advance!
Hi @TABAN, please refer to the screenshot below.
Thanks you dear , some extra clicks but it works.
You’re welcome @TABAN. If you’re using a DJ controller, you can also MIDI map a button for this:
does this work with the Rane 72 MK 2 too? I dont get which side of the earphones it will route the sound? Deck 1 or 2?
I’m pretty sure it should work on that hardware @djessa. Track Preview Audio is routed directly to the headphones. There’s no Deck 1/2 like normal headphone cueing.
