Prime 4 and djay
I see the latest update now supports Denon Prime 4. How do I set up an iOS device on the prime 4?
Hi @Craig2,
In order to guarantee perfect communication between your supported controller and djay for iOS, please connect the controller to your iOS device following these steps:
  1. Connect the Lightning or USB-Adapter to your iOS device
  2. Power the adapter through its designated power connector [12W]
  3. Connect the controller to the adapter to guarantee perfect communication
  4. Start djay for iOS
Let me know if you have any further questions.
Cheers,G
Thanks, so I’m attaching the blue cable from the prime 4 to the lightning adapter? Do you have any details about the mapping and functionality of the prime 4 unit with djay?
