Prime 4 support questions
I’m interested in the prime 4 (plus actually I know it’s not officially supported yet, hopefully in the future).
I have a couple of questions:
When using strictly as a controller, can you still use the internal hard drive with an external computer running djay pro? Can you flip down the Prime screen while using an external computer?
Hi @greenkhidr, you cannot use the Prime 4 internal drive when in computer mode. Yes, you can lay the Prime 4 screen flat when using an external computer.
Thanks for the quick response.
Trying to navigate my first foray into controllers coming from vinyl. It seems you have to make a compromise somewhere or another with every option out there! Liking your software.
Wish there were more top of the line class compliant controllers.
You’re welcome @greenkhidr. I personally own a Prime 4 and absolutely love using it with djay. My preference is running djay on an iPad. I put the cover on the Prime 4 screen and set the iPad on it. Works great!
Oh sweet.
I didn’t realize prime and iOS got on well together.
Thanks for the info.
