Device model (e.g. 2020 iPad Air 4th Gen) :
Version of operating system (e.g. macOS 14.4.1) :
Version of djay (e.g. 5.1.2) :
Hardware/controllers used (e.g. Reloop Mixon 8 Pro) :
Hardware firmware version (e.g. 1.0.1) :
Please consider sharing a short video or screenshots to help clarify your question
YOUR QUESTION:
New update of djay pr/engine dj also
The crossfader never starts the play button on the opposite deck (enabled)
Job wheel movement jumps when trying to move to begging of song/cue point,
Already analysed songs dont dissapear but the bpm and key does after not using for a few days
Thank you
Hi @Smiggylad , sorry to hear you’re experiencing this issue. if You recently updated to Windows 11 35H2, please refer to the following help topic that includes some workarounds for issues introduced with the new Windows MIDI 2.0 introduction:
Microsoft has started the rollout of the new Windows MIDI Services, which contain known issues that may prevent some DJ controllers from working correctly. This article walks you through checking for the affected updates, and uninstalling them to...
None of them updates are on my laptop already learned in feb and removed , so its the new djay update
Thanks for confirming @Smiggylad . I recommend you try the following then:
Open the official Microsoft Store and use Check for updates to make sure djay is fully up to date.
If that doesn’t clear up the issue, please try the following next: Release WinRT MIDI 1.0 Timestamp Fix · microsoft/MIDI · GitHub . The files required to apply the fix can be found in the “Assets” section at the bottom of the guide.
