I was a couple of hours into my set when the music suddenly stopped and djay pro just immediately shut down without warning. Luckily I had an ipad on standby but it still killed the vibe of the night which had been a tough gig anyway!!
I was typing in a search box at the time trying to find a song.
Hi Lukas, thanks for the update. Do you have sufficient information to investigate this issue? Are you able to provide any information on the cause? Thanks, Kyle
Thanks Lukas, hopefully you can provide a quick fix as this has happened a few times, fortunately only once at a gig however I’m constantly worried that it will happen again so the enjoyment factor of using the software is not there if there is a risk of recurrence.
