Pro Tip: Keep Sync Active While Pitching the Inactive Deck on Controller
If you’re using a controller (works for me on Pioneer REV7) and find it frustrating that Sync gets deactivated when you adjust the pitch on the inactive deck (e.g. you’re previewing a track or setting it up while the other deck is live), here’s a little Trick to save your workflow:
:wrench: Do this:
  1. Go to your MIDI settings in djay Pro.
  2. Set the Crossfader assignment to “Video Crossfader” instead of the default.
:bullseye: Why this works:
With this setting, Sync will no longer break when you move the pitch fader on a deck that isn’t currently in the mix — even if you’re not in a transition.
:white_check_mark: That means you can:
  • Pitch tracks freely on Deck A or Deck B while staying in SYNC all the time
  • Keep your transitions tight and your workflow smooth
Perfect for preparing tracks or layering next-ups — without losing the beatgrid / sync connection. Give it a try!
hey Essa, is this tip still working? This would be my main problem fix with DJay Pro cause im so used to how Serato syncs and it never falls out of Sync there
no after update 5.3.3. this isnt working anymore :frowning:
