I recently upgraded to the latest version iPad app and there appears to be a bug. When I select the recording format as WAV in settings it still records the file as a low quality 128kbps m4a file.
I tried changing the format and then changing back but it still won’t record in WAV. I want to record in the higher format so I can convert it to iTunes quality 256kbps, although my preference would be to have the option to set bitrate and record to standard iTunes quality out of the box.
This needs fixing really
